DRC ERROR
Hello Sir,
              When i am compiling my project, i am getting the error as : [DRC 23-20] Rule violation (RTSTAT-1) Unrouted net - 2 net(s) are unrouted. The problem bus(es) and/or net(s) are DUT1/PCIE_RF_bus_i/axi_pcie3_0/inst/pcie3_ip_i/inst/gt_top_i/pipe_wrapper_i/pipe_lane[0].pipe_quad.gt_common_enabled.gt_common_int.gt_common_i/qpll_wrapper_i/int_qplloutclk_out[0], DUT1/PCIE_RF_bus_i/axi_pcie3_0/inst/pcie3_ip_i/inst/gt_top_i/pipe_wrapper_i/pipe_lane[0].pipe_quad.gt_common_enabled.gt_common_int.gt_common_i/qpll_wrapper_i/int_qplloutrefclk_out[0].
how to resolve this issue?
Anuradha C
garethc
Hi anuradha.c@mistralsolutions.com
Please take a look at AR:65502 that provides details on how you can initially debug this and check if the workarounds work or you.
https://www.xilinx.com/support/answers/65502.html
Gareth
Versal Blogs
hello sir,
           I am using the PCIE and aurora interface in same quad. i am generating the project using vivado 2015.2. i am getting error which generating the bitstream. when i see pcie its have GTH_common and qpll inside the ip which i am not able to change. i have aurora interface i tried to give clock to the interface from adjacent tile because PCIe ip is not providing any reference clock output. i am not able to generate the bitstream. how to resolve this issue?
garethc
Please create a new post if you are seeing another issue from your original post.
Gareth
Versal Blogs
