ouadrani
Data reading through PCI express
Communication is done from pc to ML506 through pci express and from the ML506 to the PC through the uart.
I use the driver Met to write data from PC to the ML506 .
My design through xps contain :the plbv46 endpoint bridge ,the microblaze and the the ddr2.
Through the hyperterminal when I try to read what I wrote, everything ; from  85C00000 ( base addr ) to 85C007FF is at 0 excepet these adresses  :
The address is 85C00030 and the data is : 107
The address is 85C00031 and the data is : 107
The address is 85C00032 and the data is : 107
The address is 85C00033 and the data is : 107
The address is 85C00034 and the data is : 200
The address is 85C00035 and the data is : 200
The address is 85C00036 and the data is : 200
The address is 85C00037 and the data is : 200
The address is 85C00038 and the data is : 2
The address is 85C00039 and the data is : 2
The address is 85C0003A and the data is : 2
The address is 85C0003B and the data is : 2
The address is 85C0003C and the data is : 60
The address is 85C0003D and the data is : 60
The address is 85C0003E and the data is : 60
The address is 85C0003F and the data is : 60
The address is 85C00040 and the data is : 84000
The address is 85C00041 and the data is : 84000
The address is 85C00042 and the data is : 84000
The address is 85C00043 and the data is : 84000
And this is the same even if I do not write anything.
Where can I found my data ?
In working in linux .
luisb
You need to verify the translation between the addresses on the PCIe side and on the PLB side.  They usually do not correlate 1 to 1.
