10-08-2018 04:01 AM
I'm using the VC707 fpga card and i want to transfer the data that i wrote on the DDR3 memory to a PC.
I Have gone throught the VC707 PCIe tutorial https://www.xilinx.com/support/documentation/boards_and_kits/vc707/2015_1/xtp207-vc707-pcie-c-2015-1.pdf
But i'm facing a couple of doubts:
1) The PCItree software works only for 32 bits system, I have a 64 bits Windows 10 PC
2) I have connected the VC707 to my computer with JTAG cable and to the power supply:
Should i keep the VC707 powered on by the PC power supply while i plug the VC707 into a PCIe slot?
3) I don't know what is the next step to be able to connect the output of my DDR3 memory MIG to the PCI e design so i can send the data from the DDR3 to my PC.
10-11-2018 11:41 AM
Hi @cassandra
There are other available PCIe software applications available for Windows. You might check out Teledyne Lecroy Telescan PE, lspci for Windows, or others available as freeware / shareware.
For powering, when physically removing or plugging the card, you should disconnect all power - PC and VC707 power supply. If you are going to power via the PC, you will need to use the instructions in the board User Guide (as it is not a standard 6 pin power supply connector) and you will need to program the PROM on the board to load the FPGA.
For a MIG-PCIe design, including upstream bus mastering, you might consider the architecture shown in these videos:
https://www.youtube.com/watch?v=0KnvW_6Bgu0
https://www.youtube.com/watch?v=TzzzM97L4HI&t=376s
The videos show these cores on the Gen3 capable parts, but the same cores are available in the 7-series devices as well.
