rbryan3
Editing MCAP Register Base in MCAP driver for Windows 10
I read that there is an issue using the xilinx mcap driver with Ultrascale+ devices in that the start of the MCAP VSEC points to the wrong address.  I am attempting to change the base value from 0x340 to 0x350 but I cannot find any instructions with regards to building the driver.  When I do try to build I get a warning saying "MSB8005: The property 'NMakeBuildCommandLine' doesn't exist."  Is there an updated mcap driver for windows 10?  I am working with a VCU118 in Vivado 2020.2.  Or has anyone ran into this and been able to figure out how to build the driver?
Thank you,
Kyle
Tags (3)
pvenugo
@rbryan3 ,
Please refer to https://xilinx.github.io/dma_ip_drivers/master/XVSEC/xvsec_linux/index.html for MCAP latest driver.
Praveen
rbryan3
@pvenugo ,
Thank you for responding, I was looking for info on windows 10 drivers though.  Our team ended up switching to a linux redhat machine and was able to utilize the linux mcap drivers.
