Enabling Tandem PROM in the PCI EP core configuration menu
I have a fully functioning and working FPGA design on a Kintex 7 part that involves a DMA/Bridge Subsystem core for PCI-e. I faced issues with the device enumerating and so I am in the process of recreating a tandem PROM bit stream. However, when I try to reconfigure the PCIe EP core (inside the DMA hierarchy) the Tandem Prom checkbox is always greyed out. It is also greyed out if I try to generate a brand new PCIe EP.
What is the cause of this?
Xilinx Part: xc7k70tfbg484-1 (active)
PG195 mentions the following under "Unsupported Features".
Tandem Configuration solutions (Tandem PROM, Tandem PCIe, Tandem with Field Updates, PR over PCIe) are not supported for Virtex®-7 XT and 7 series Gen 2 devices.
Kintex-7 comes under 7 series Gen 2 devices.
