Visitor ashish_wezzy
FPGA connection with PC through PCIe
I am having Vertex 5 ml507 FPGA board , I want to connect it with PC through PCIE port in motherboard. And how I check it will be connected in the PC.
Scholar jg_bds
Re: FPGA connection with PC through PCIe
The OS of the PC will detect the PCIe add-in card during system enumeration.  You should be able to query the OS to list the discovered devices--e.g., lspci, in Linux.  One of the reported devices should be your add-in card.
-Joe G.
So, i don't need to install any driver for connection.
and if i want to dump any program into it, how i do it?
Scholar jg_bds
I don't understand "dump any program".  But, yes: if you need to do anything with the PCIe (beyond checking the status of the basic, standard link), you'll need some sort of driver to configure the end point and move data across the link.
-Joe G.
If I want to write a program for led blinking. So, in which programming language I have to write, like in C,C++ or VHDL.
I think through PCIe port connection we not flash the vhdl code in FPGA.
So, what the process to code the FPGA directly.
Scholar jg_bds
