Gated Clock in V5 PCIe Endpoint Block Plus v1.11 ?
during bitgen of the PCIe Endpoint Block Plus example design which comes with the core I got the following
warnings about gated clocks:
Release 11.2 - Bitgen L.46 (lin)
Copyright (c) 1995-2009 Xilinx, Inc.  All rights reserved.
WARNING:PhysDesignRules:372 - Gated clock. Clock net
   ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/icdrreset<1> is sourced by
   a combinatorial pin. This is not good design practice. Use the CE pin to
   control the loading of data into the flip-flop.
   ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/icdrreset<2> is sourced by
   ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/icdrreset<3> is sourced by
   ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/icdrreset<0> is sourced by
Is this a known problem ?
Can we ignore this warning ?
I used ISE 11.2 tool chain on 64bit Linux OS.
Anonymous
Not applicable
Re: Gated Clock in V5 PCIe Endpoint Block Plus v1.11 ?
refer to pcie_blk_plus_ug341.pdf
This warning can be ignored.
