[HELP] Does PCI Express Communication Need DMA?
I'm now using this core to accompllish communications between 2 ML507 boards. But after I finished the codes as indicated by the User Guide, when I'm trying to send a packet from board A to board B, I find when the time the packet sent out from A, the operating system will die. And I find board B doesn't get any packet from A. Does the communication between 2 PCI Express devices need something else such as DMA?
The 2 boards are connected to a switch chip( produced by IDT, name is 22H16), and this switch is connected to a x86 system.
Message Edited by sdbzlh on 07-08-2009 12:18 AM
Hu LI
Advisor
Advisor
Re: [HELP] Does PCI Express Communication Need DMA?
You're saying that the operating system on x86 system dies. But you're sending a packet from A to B.
It might be that the destination address of the packet is x86 system, not B.
OutputLogic
Tags (2)
Thank you, but I am sure that the packet destination is B not the CPU, for CPU has no such memory address at all. I use CHIPSCOPE to examine the packet sent by CPU to B, and get the destination address, which is the address of B. Then I use this address in the program in A to send a packet to B. But then the whole system died.
Hu LI
Oh, thank you very much. But I want to establish the communication between several boards(more than 30) using a switch chip. So do you have any other suggestions?
Hu LI
