falikhan
HTG-v5-pcie-LX330T PHY Problem
hi everyone!  is marvell PHY 88e1111 on HTG-v5-pcie-LX330T  board require explicit reset after powerup the board to ensure proper operation? bcs when i loaded the bit file of example design generated with embedded temac all leds  connected with PHY A goes down? i didnt use explicit reset. did someone face the same problem with the same board using the same design? any help in this matter would be most appreciable!
Anonymous
Not applicable
This looks like this would be better answered in a different forum. I will move this over for you so that you can get an answer
