How to simulate two PCIe cores
I generate an EP core and a RP core separately in my project.  In the sim top file, I instanced them as two module. Just like:
xilinx_pcie_2_1_rport_7x RP (
  // SYS Inteface
  .sys_clk_p(clk_sys),
  .sys_clk_n(~clk_sys),
  .sys_rst_n(sys_rst_n),
  // PCI-Express Interface
  .pci_exp_txn(rp_pci_exp_txn),
  .pci_exp_txp(rp_pci_exp_txp),
  .pci_exp_rxn(ep_pci_exp_txn),
  .pci_exp_rxp(ep_pci_exp_txp)
 PCIe_TOP EP(
    .sys_clk   (clk_sys),
    .RESET_N   (sys_rst_n),
    .pkt_gen_ren    (tc_ren_p0),
    .pkt_gen_dati   (tc_dati_p0),
    .pkt_gen_empty  (tc_empty_p0),
    .pkt_gen_ctl_ren(tc_ctl_ren_p0),
    .pkt_gen_ctl_din(tc_ctl_din_p0),
    .pci_exp_txn(ep_pci_exp_txn),
    .pci_exp_txp(ep_pci_exp_txp),
    .pci_exp_rxn(rp_pci_exp_txn),
    .pci_exp_rxp(rp_pci_exp_txp),
    .pcie_clk (user_clk),
    .pcie_reset_n (pcie_reset_n)
But when run simulation, the RP core's user_clk_out always be "Z", it seems that the RP core doesn't work normally.
Can I use two PCIe core in the same design?
Thank you!
vsrunga
HI,
Looks lke duplicate post of
http://forums.xilinx.com/t5/PCI-Express/the-quot-user-clk-out-quot-always-be-quot-Z-quot-state/td-p/390671
