rohithcs
Interface PC and FPGA using PCIe
Is there a step by step proceedure of interfacing PC and FPGA using PCIe for KC705
nagabhar
HI @rohithcs
if using linux , then lspci /setpci  system tools itself should do.
For windows 7 and 10  OS:
use RWeverything
https://rweverything.com/
Teldyne Telescan also is free and good to use
http://teledynelecroy.com/protocolanalyzer/pci-express/telescan-pe-software
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
gnarahar
@rohithcs Check PCIe Example Design for KC705
https://www.xilinx.com/member/forms/download/design-license.html?filename=xtp197-kc705-pcie-c-2014-3.pdf&cid=370265
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
rohithcs
@gnarahar
Here in the mentioned link, It says PciTree does not work with 64bit windows, any work around for this?
rohithcs
@gnarahar
also i am unable to figure out how to generate the mcs file, any help would be appreciated.
The commands mentioned in the pdf do not work but i am able to proceed till generation of bit file for the process.
gnarahar
@rohithcs I am not much aware of the workaround. Will ask a PCIe expert to look into this.
- Giri
nagabhar
HI @rohithcs
use RWeverything
Bharath
wh1t3w0lf
Hi @rohithcs,
I suggest that you use the IP named 'DMA Subsystem for PCIe'. It supports the FPGA device on your KC705 and you can utilize the provided Linux/Win driver to initiate DMA transfers between your host and the FPGA board.
