Is XAPP869 (Point To Point Connectivity Using Integrated End Point Block for PCIe Express (Target Virtex 5)) being ported to Spartan 6?
Can it be Ported to Spartan 6?
Nick
There are no plans to port this app note to Spartan-6. The Spartan-6 block is not capable of interfacing directly with another Spartan-6 block so the techniques in this app note cannot be applied.
To connect two Spartan-6 devices together, you would have to do a peer-to-peer type setup through a switch.
You could also connect a Virtex-6 device using it's block in root port mode to the Spartan-6 endpoint.
-John
