Is two end points in one Spartan 6 possible?
Can a Spartan 6 have one end point using the hardened block and a second endpoint using IP (Northwest or PLDA)?
Nick
Yes, if you have enough room it should be possible to use the integrated block and  a soft endpoint.
John
