hepml
KCU105 PCI Express Control Plane TRD Control & Monitoring GUI crashes on Write operation
I am using KCU105 Evaluation Board via PCIe on CentOS 7.
I am following the example "KCU105 PCI Express Control Plane TRD" (https://www.xilinx.com/support/documentation/boards_and_kits/kcu105/2015_2/ug918-kcu105-pcie-control-plane-trd-ug.pdf).
Loading the bitstream, detecting the board and setup and installation of the Control & Monitoring GUI (figure 3-14) work fine.
Reading via PCIe works fine as well.
However, when I try to write (address: 0x0 value:0xabcdef12) the whole system crashes, and the machine reboots.
Attached is the screen after crash.
I would appreciate some hints quite a lot!
hepml
The error message I get is:
The BIOS has corrupted hw-pmu resources
