Visitor tharvid
Kintex 7 AXI clock
I have a 100 MHz clock for PCIe use. Can i use this for the AXI-interface? I can only choose 62,5 or 125 MHz when generating the IP. Do i have to change the 100 MHz clock to a 125 MHz?
Regards, Thomas
Scholar kotir
Re: Kintex 7 AXI clock
Hi ,
The referance clock is different from AXI clock.
The PCIe IP that gets generated is wrapper of the PCIe hard block and the MGT(GTX for K7).
The referance clock is taken from the PCIe connector that comes from link and provided to MGT.
The txoutclk from the MGT is provided to MMCM which will generate the core clocks and user clock.
The mmcm will be in the file <corename>_clock.v/vhd
The choice of the axi clock frequency maintains the data rate at link side with userside.
So you need to use the axi clock that core provides to interface user application.
Koti Reddy
Scholar kotir
Hi ,
Koti Reddy
