Visitor painkil
Kintex Ultrascale+ Tandem PCI Express Bank#65 PERST problem.
I'm planning a project with XCKU3P-2FFVB676. (which has 4 HP banks, 64,65,66,67)
I need Bank#65 to use it in DDR4 Memory 64 bit (3 banks should be in consecutive, so I sould use 64~66 or 65~67)
Because of PCI Express configuration Time Limitation (<100ms) I also need Tandem PROM configuration method with dual or single QSPI memory.
I think single QSPI memory is enough when I operate QSPI flash at 66MHz (if first stage is lower than 2MByte, 60 ms will be elapsed)
But, PERST dedicated route pin making me difficult to plan pins.
So, I want to know if I can move this pin to bank#64 with dedicated route option with Tandem PROM.
Is there other solution both limitations meet?
Please tell me.
Thank you.
Best Regards,
Re: Kintex Ultrascale+ Tandem PCI Express Bank#65 PERST problem.
when using tandem configuration, bank65 cannot be used for MIG. This is pointed out in PG213.
you might check the following link in case you want to use bank65 without enabling tandem
https://www.xilinx.com/support/documentation/application_notes/xapp1338-fast-partial-reconfiguration-pci-express.pdf
Visitor painkil
Thank you for your reply kkn.
I’ll check your recommendation and I’ll make another post if I have any further questions.
Thank you
