08-19-2010 07:26 PM
My board is designed with PCIe hardcore of spartan 6 FPGA. And I edited the FPGA core based on the one generated by the core generator (V12.1).
After I did some change, the core seems get unstable. Sometimes, the original detectable PCIe core will be undetectable ( by lspci in linux, or pci in dos).
There is one case that I tried a lot of times and the result is consistent. In the project, I named one out group pins as "io_lvLED_PCIe". The core can be detectable with "lspci" or "pci" command. But when I changed the name to "io_lvPCIeLED" ( it is the only change, both in top file and ucf file), the core (can be successfully compiled) becomes undetectable.
And I compared these two situations, same warning messages and same resources are used. I didn't find any difference between them.
I am wondering whether there is any one has such experience. I appreciate if someone can give me any clue about it.
08-20-2010 11:11 AM
It is solved.
After connecting sys_reset_n in PCIe core to system reset signal, the core gets stable and can be always detected.
08-20-2010 11:11 AM
It is solved.
