Visitor kailassenan
ML605 PCIe x8 Gen2 Reference Design
Can i know the availability of ML605 PCIe x8 Gen2 reference design files? I am looking for PCIe x8 Gen2 Root port configuration in ML605.
Re: ML605 PCIe x8 Gen2 Reference Design
x8 Gen2 needs -3, -2 devices. ML605 comes with -1 device.
x8 Gen2 support is only available for endpoint configuration.
If you want reference designs, you may just generate your core in gen2 and root mode. There will be an example design that comes with it which you may just implement and run in on your hardware.
-Yan Shun Li
Visitor kailassenan
HTG-V6-PCIE (from Hitech Global) comes with -2, -3 speed grade. Currently the Virtex-6 Integrated Block for PCI Express core v1.5 supports x4 gen2 / x8 gen1 for root port configuration. The core supports x8 gen2 for end point configuration.
I am looking for the Virtex-6 Integrated Block for PCI Express which can support x8 gen2 root port configuration.
