mengmcxl
MPSOC PS PCIe EP DMA register access issue
I use ZCU102 MPSOC PS PCIe EP DMA. The host can access the DMA registers with BAR0. But PS cannot access the DMA registers. I see the DREG is 0 somehow. It should be non-zero. Here is more detail:
We are using Zcu102 as PCIE Endpoint and Xeon COMe main PC as Root point.
     In COMe root complex side, we can use “lspci” find PCIE bus address map and can expected results for AXI_PCIE_DMA Register following below:
https://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.htmlhttps://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.html
But in FPGA side:
All of these registers’ values are all 0  and can’t be written by memory utility.
./devmem2 0xfd0f007c w
         00000000    ----- expected 00008000
./devmem2 0xfd0f00fc w
         00000000    ----- expected 00008010
  ./devmem2 0xfd0f0050 w
         00000000
  ./devmem2 0xfd0f0050 w 0x5555
          DMA_CHANNEL_SCRATCH0 (AXIPCIE_DMA) Register --0xFD0F0050 is a rw register and it should be written as value 0x5555
        00000000    ----- expected 00005555
Ho can we get the expected results in this zcu102 PCIE endpoint?
garethc
Hi @mengmcxl
The ZCU102 board will not work as a PCIe Endpoint due to two main reasons:
1. The ZCU102 card provides a PCIe reference clock and puts it on the PCIe connector. This is incompatible when trying to be an EP as the host will be providing the reference clock.
2. The level shifter for #PERST is an output and not an input as would need to be for an EP.
Gareth
Versal Blogs
I have the same issue, I also opened a new thread:
https://forums.xilinx.com/t5/PCIe-and-CPM/PCIe-Address-Translation-RunTime-Configuration/m-p/1087594
My board is properly configured as endpoint, it works properly, I only need to runtime pass a parameter from windows host to the ultrascale+ endpoint. I'm able to read and write DMA_CHANNEL_SCRATCH0 register from windows driver but I can't access from PS Zynq code.
Could you help me?
Nicola
