Visitor swong_ti
Migrating PCIe PHY IP from VU3P device to UV37P device
We just got the UltraScale+ HBM VCU128 Evaluation board. I am trying to migrate the PCIe PHY IP from VU3P device to VU37P device. The Vivado's tools (2019.1 or 2018.3) does not allow me to upgrade PCIe PHY IP to VU37P device, which I am going to use in VCU128 Evaluation board.  Can someone direct me how to generate the PCIe PHY IP for VU37P device?
I have attached the screenshot of the vivado's tools. Please let me know, if there is any workaround to generate PCIe PHY IP.
回复: Migrating PCIe PHY IP from VU3P device to UV37P device
vu37p is not currently supported for the PCIe Phy generator.
You can 1 generate a PCIE IP and split the pipe interface from it manually
2 use a PHY IP supported device as  target device to generate core and modify the locations manually.
The settings of GT for the devices of the same series are similar in the IP
