jmantzouranis
Minimum Latency of QDMA subsystem for PCIe
Hi all,
What is the minimum latency for a 300-byte packet, for instance, using the QDMA subsystem for PCIe, from host to FPGA (VU9P)? There only seem to be measurements and documentation related to throughput.
https://www.xilinx.com/products/intellectual-property/pcie-qdma.html
https://www.xilinx.com/Attachment/Xilinx_Answer_71453_QDMA_Performance_v6.pdf
kurihara
If it is the minimum value, I recommend measurement by simulation. In actual measurement, it is difficult to trigger the start point and end point, and the environment of the platform has an effect.
liy
There is a way to measure the latency in the file you mentioned
please check chapter Latency Measurements
jmantzouranis
Has anyone measured this and have an approximate/ballpark value?
vconst89
The question is still open. @liy @kurihara , is it possible to ask Xilinx to publish a latency measurement report?
