Motherboard selection for PCIe with large BAR
I am working on a ultrascale+ with HBM2 design and want to make the full 8GB available to the host. Most motherboards are limited to a 32b address space and will not be able to support this.
How can I identify motherboards that support accessing the full 8GB?
Don't have much information on this. There is 'Above 4G Decoding' option in the BIOS in some systems. If that is enabled, you should be able to access larger memory. Did a quick search in google, looks like there are some additional information on this.
Hello there,
If you wish to memory map a huge amount of memory on your PCIe, you have to:
  • Enable UEFI
  • Enable 4G Above decoding in your BIOS (As previously mentioned by @deepeshm,)
  • Install your OS with UEFI
  • You may also need to add "pci=nocrs" to grub
All motherboards since many years support it.
