Visitor sdmello
Occasional "Synchronous External Abort" on PCIe read. Zynq Ultrascale. SDK 2019.1
On our Zynq UltraScale+ MPSoC-based customboard, we very rarely see this issue when Linux is booting up.  The exact point at which this exception is encountered is in pci_generic_config_read called by nwl_pcie_probe.
[    3.128810] nwl-pcie fd0e0000.pcie: Link is UP
[    3.136132] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges:
[    3.143103] nwl-pcie fd0e0000.pcie:   MEM 0xe0000000..0xefffffff -> 0xe0000000
[    3.150324] nwl-pcie fd0e0000.pcie:   MEM 0x600000000..0x7ffffffff -> 0x600000000
[    3.157904] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[    3.164081] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.169564] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[    3.176433] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[    3.235478] Internal error: synchronous external abort: 96000210 [#1] SMP
[    3.242252] Modules linked in:
[    3.245293] CPU: 0 PID: 59 Comm: kworker/0:1 Not tainted 4.19.0 #1
[    3.251461] Hardware name: xlnx,zynqmp (DT)
[    3.255637] Workqueue: events deferred_probe_work_func
[    3.260759] pstate: 20000085 (nzCv daIf -PAN -UAO)
[    3.265536] pc : pci_generic_config_read+0x34/0xb0
[    3.270316] lr : pci_generic_config_read+0x20/0xb0
[    3.275088] sp : ffffff8008dbb870
If it helps, here's the pcie node of the decompiled dtb. I've also attached the complete boot log;
pcie@fd0e0000 {
compatible = "xlnx,nwl-pcie-2.11";
status = "okay";
#address-cells = <0x3>;
#size-cells = <0x2>;
#interrupt-cells = <0x1>;
msi-controller;
device_type = "pci";
interrupt-parent = <0x4>;
interrupts = <0x0 0x76 0x4 0x0 0x75 0x4 0x0 0x74 0x4 0x0 0x73 0x4 0x0 0x72 0x4>;
interrupt-names = "misc", "dummy", "intx", "msi1", "msi0";
msi-parent = <0xf>;
reg = <0x0 0xfd0e0000 0x0 0x1000 0x0 0xfd480000 0x0 0x1000 0x80 0x0 0x0 0x1000000>;
reg-names = "breg", "pcireg", "cfg";
ranges = <0x2000000 0x0 0xe0000000 0x0 0xe0000000 0x0 0x10000000 0x43000000 0x6 0x0 0x6 0x0 0x2 0x0>;
interrupt-map-mask = <0x0 0x0 0x0 0x7>;
bus-range = <0x0 0xff>;
interrupt-map = <0x0 0x0 0x0 0x1 0x10 0x1 0x0 0x0 0x0 0x2 0x10 0x2 0x0 0x0 0x0 0x3 0x10 0x3 0x0 0x0 0x0 0x4 0x10 0x4>;
power-domains = <0xc 0x3b>;
clocks = <0x3 0x17>;
xlnx,pcie-mode = "Root Port";
xlnx,tz-nonsecure = <0x0>;
linux,phandle = <0xf>;
phandle = <0xf>;
legacy-interrupt-controller {
interrupt-controller;
#address-cells = <0x0>;
linux,phandle = <0x10>;
phandle = <0x10>;
The SDK version is 2019.1.
Any help is much appreciated, thanks!
