Visitor lyuanjie
PC hung and failed to boot-up after restart
I have plugged a VC707 card into a 32-bit Lenovo ThinkCentre Core 2 Duo E8400 desktop to verify my PCIe end-point design with DMA engine. To check the setup, I have first programmed Xilinx PCIe reference design (xtp144) into VC707 using JTAG and used PCI Tree to detect it. After a PC restart, the system was able to boot-up and PCI Tree was able to detect the plugged-in card.
When I programmed my customized end-point design with DMA engine into the VC707 in the same manner, the system simply hung and failed to boot after restart. I could hear the PC fan blews stronger than normal (as if there are some conflicts). However, it continued to boot-up when I switched the VC707 off.
Can someone kindly point me in the right direction on how to debug the problem? What could be the possible causes of it? I have seen AR34873 (http://www.xilinx.com/support/answers/34873.htm). Could this be the reason? Should I try it on another PC?
Voyager
Voyager
Re: PC hung and failed to boot-up after restart
Does your card requires lots of current? Maybe the mother board can not provide so large current.
Observer danbo.liang
Do you simulate your design?
the possible reason is:
1) when boot up, your design send interrupt frequently
2) the physical address of DMA is wrong, this physical address is got from a virtum address by a address transform function
3) you should take off you card, then boot up, then delete pcie's driver in system32/drivers
