dimkar
PCI-Express PIPE DMA controller
We have developed a multichannel (16 rx, 16 tx) scatter-gather DMA controller for Spartan PIPE PCI-Express endpoint. But our main project has been closed. Are there any interesting people to use our controller?
bzigon
I too am using the Spartan-3 PCI Express board. I have a simple design that needs to read a matrix in
from main memory. Could I try using your dma controller? I am learning how to write one.
jamesatalltek
Is there any document about the DMA controller ?
luisb
If you want all the bells and whistles of a DMA controller, I would look at the Northwest Logic core.  It comes at a cost, but it's a popular solution.
http://www.nwlogic.com/packetdma/
If you want to learn about a basic DMA engine used with our core, then I would look at XAPP1052:
http://www.xilinx.com/support/documentation/application_notes/xapp1052.pdf
XAPP1052 isn't as user-friendly as the Northwest Logic core, but it's free and teaches you about a PCI Express DMA engine.
Hope this helps...
deepeshm
dimkar
You can read the description from http://intensys.com/images/stories/pci%20express%20sgdma%20ip%20core%20datasheet.pdf. It's a new, 64-bit version of controller. 32-bit version is under development and it's intended primary for spartan-6, but it can be adopted for spartan-3 as well.
