PCI Express lane polarity invertion
Hello!
I have Virtex 6 based board with PCI Express interface. I'm using "Virtex-6 FPGA Integrated Block for PCI Express v2.5" . I have generated Verilog sources from core and added these sources to my project.
As noticed in core's user guide it supports polarity invertion on receiver side of the lane.
Question is: how can I change polarity? Wizard allows to enable only Lane Reversal.
Professor
Professor
Re: PCI Express lane polarity invertion
In case you didn't get enough information from AR #18529, the point is that receive lane polarity inversion is automatically detected during training, so you don't need to enable anything.  If you want to reverse the lane polarity to help routing, just swap the pins at the board level.  Don't change the pinout in the .ucf file, i.e. for the purpose of your design, the + and - side of the pair keep the name of the pin function even though they connect to the opposite polarity signal at the board level.  During training, the PCIe endpoint logic will detect the inverted polarity and automatically correct for it.
Likewise, because polarity inversion is automatically handled by a compliant receiver, the transmitter can be connected with reversed + and - wires if it helps board-level routing.  There is no need to invert the polarity of the transmitted signal to compensate for the swapped wiring.
-- Gabor
Another question. Should I swap pair's LOCs in .ucf-file after inversion?
The below published answer record address your query
http://www.xilinx.com/support/answers/33699.htm
Also refer http://www.xilinx.com/support/answers/18529.htm
FYI:
Please check the following link for the check supported pinouts section.
http://www.xilinx.com/support/documentation/ip_documentation/pcie_7x/v3_0/pg054-7series-pcie.pdf
If you are connecting something different than these it is up to you to make sure the timing and functionality of the design.
Professor
Professor
-- Gabor
umamahe, gszakacs, thank you very much! This is exactly what I need.
