atrajesh
PCI tree for 64-bit machine
We recently purchased ML605 kit. We are having 64-bit HP workstation. The PCItree software doesn't work on 64-bit machines:
http://pcitree.de/download.html
Can someone suggest some software which works for 64-bit machines. Is there any other way of sending and receiving data from the ML605 through PCIe.
thanks in advance,
rajesh
maschmi
I`m facing the same problem on a Windows 7 64bit machine.
I tried "HWDirect" from Eprotek (www.eprotek.com) but it`s shows nearly the same text "Error! Load driver failed!"
Did you got a solution in the meantime?
Best regards
Marc
atrajesh
Hi Marc,
I have now switched to a Windows 32-bit machine. PCI Tree is running fine here, and I am able to see ML605 here.
I had raised a case, and it seems that there is not free software for scanning PCIe devices on 64-bit machines.
regards,
rajesh
maschmi
Hi Rajesh,
in the meantime I tried to different software packages on Win7 64bit.
HWDirect (www.eprotek.com/) and PCIScope (www.tssc.de).
PCIScope has a 15day trial.
HWDirect needs you to press F8 at system boot and then deactivate driver enforcement. After windows start you have to run HWDirect as administrator!
You can scan your PCI devices and write manually values into the memory of XILINX chip ("ML605 PCIe x8 Gen1 Design Creation").
Hope that helps.
Best regards,
Marc
sroche
Ran into the same issue when working on XTP197 (KC705 PCIe Design)
RWEverything works well on win7-64 and is free.
It allows, among other things, to  access PCI config and read/write PCI registers.
con: does not display a nice PCI Tree.
pro: batch file and command line mode. It should be possible to control PCI registers from any programming language via command lines.
numbat
Jungo makes a toolset called WinDriver which includes a wizard to assist in displaying PCI devices and even churn out some driver source.  I've tried the Cygwin C example code talking to their base kernel driver and it seems to perform as expected against the ML605 PCIe x8 project.
I've sunk about a total of 30 minutes into their free evaluation platform, so caveat emptor.
Stacey
opher
Jungo Connectivity also has a free tool called "WinDriver PCI Viewer" which is basically with all the functionality of the pci-tree with support for 32/64 bit, you can view the configuration space and more.
It is based on the commercial WinDriver but the viewer comes as a free tool.
Opher
Jungo Connectivity
kotir
Hi ,
You can use system information viewer
http://rh-software.com/
KR
emanuele83
Hi all,
 I just want to add the lecroy SW to the list
http://teledynelecroy.com/protocolanalyzer/protocoloverview.aspx?seriesid=447
it is free and works fine, better with win 7 (with some problems with win 10, even if supported)
We are als using the PCI scope from this germancompany
http://www.tssc.de/
it is expensive but at least it is possible to read everything from pci express configuration space
sethus
PCIe tree only supports 32 bit Windows OS
You can use SIV(System Information Viewer) which supports both Windows 32 bit and 64 bit OS
Sethu
emanuele83
SIV works but not reliably, the pciexpress configurations space is not read correctly. it does not show all values in the whole config space. only the first 256 bytes, then it writes something like "repeated every 256 bytes" and does not display all the contents. even the RW everything is not giving access to the pcie config registers. This is what I am experiencing right now, I had to use PCIscope or the lecroy SW to be able to detect our problem in the config space.
In line of principle it shall be possible to read the PCIe config space just dumping somewhere in the memory. but I am not able to understand at which address. does anybody can give me a hint?
morris_zhang
yes,I try to use pciscope
it is a good tool
I use window 10
dag1
To add to your question, I have a 32-bit Linux machine (Intel based processor). Does anyone know of a PCITree like Application that runs on Linux ?
I am trying to set up a Kintex 705 board in order to learn how to use the PCIe IP once installed on the FPGA
ali.naved92
I'm trying to do the same thing. Did you happen to find a good solution?
rkvr
try pcimem linux based c code. I used for Xilinx EP IP testing and it able to perform Byte, Word, Double word Memory write read.
https://github.com/billfarrow/pcimem/blob/master/README
davenut86
On linux you can use the lspci and setpci from a terminal.  There is also an .exe you can use on windows.  Also if you don't mind paying for one there is Arbor by Mindshare.  It has a nice Tree view and allows you to write/run Python scripts.
https://www.mindshare.com/Software/Arbor
Here is a link for lspci and setpci on windows: https://eternallybored.org/misc/pciutils/
