sebastianro
PCIE PIO dual port RAM
I noticed that the PIO example uses a dual port RAM, a prot for writing and one for reading. What would happen if I use a single port RAM?
Sebastian
luisb
If you use a single port RAM then you can't read and write at the same time from the BRAM.  You will need extra logic to hangle this.
