Observer tsegorah
PCIE core v2.5, cannot read in Linux
Hello.
I try to make the reference design work.
I use ISE 2014.7, integrated block for PCI-e v2.4, virtex 6 xc6vsx475t, processor with Debian.
When I try to read data in linux using reference dexign from plate manufacturer, everything is ok. But it uses processor system, and I can't just take the PCI core from it with all its settings, because I don't use the processor.
So I use the other core, that is not for processor system, and it has different set of settings. Earlier I did the same in other project, and it worked, but I cannot find it.
When I implement reference project and try to read some data in linux, it freezes.
And there is no valid data on AXI too, neither during reading nor while writing.
xco file is in attachment
Observer tsegorah
Re: PCIE core v2.5, cannot read in Linux
The only activity I see when try to read is this:
Can you let me know the system configuration becasue I'm not sure what look like?
Is this add-in card design and linux is on the host machine?
Do you use the example design generated wth IP by CORE Generation?
