Observer arunkumarka
PCIE works only with 1DW
Dear all,
           I modified the AC701 PCIE Example code for higher payloads(As the example supports on 1DW).The End point Device is Artix-7 FPGA and the Host is TI's Keystone Processor.With 1DW the EDMA in the Host accepts data but with 2DW and More the Memory is filled with zeros.The images for the frame structure is given below..please comment...
regards
Arun
Tags (2)
Re: PCIE works only with 1DW
@arunkumarka,
From a quick look at your format on the TX - it looks like you have an issue with your first byte enable and last byte enable.  You have 0x80, where you would likely need something more like 0xFF.  Right now, you only have the MSB of the First Byte enabled.
Hi thank you for the reply,
Now it is working for larger payloads also.In the Host side for the BAR  we enabled the prefetch mode previously it was in the Non-fetch mode.
regards
Arun
