syamcr
PCIe DMA driver (xdma) kernel module crashes
I have successfully built the xdma kernel module from the latest sources (git). But when I insert the module, it crashes.
Kernel versions: 4.15.0-76-generic, 5.0.0-23-generic (former is a physical PC with the VC707 board, latter is just a VM)
Crash apparently happens when xdma_threads_create() calls xdma_kthread_start() 8 times in a loop. The first two iterations go fine, but the third iteration results in a crash.
dmesg output:
[ 360.387621] xdma:xdma_threads_create: xdma_threads_create
[ 360.387623] xdma:xdma_threads_create: kzalloc completed (**print added by me**)
[ 360.387838] BUG: unable to handle kernel paging request at ffffffffbee9ec20
[ 360.387870] IP: xdma_kthread_start+0x9a/0x120 [xdma]
[ 360.387878] PGD b5320e067 P4D b5320e067 PUD b5320f063 PMD fe05d5063 PTE 80003ff4acb61062
[ 360.387893] Oops: 0000 [#1] SMP PTI
[ 360.387900] Modules linked in: xdma(OE+) xt_multiport snd_hrtimer binfmt_misc nls_iso8859_1 snd_hda_codec_hdmi intel_rapl sb_edac x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc aesni_intel aes_x86_64 ip6t_REJECT nf_reject_ipv6 snd_hda_codec_realtek snd_hda_codec_generic nf_log_ipv6 input_leds crypto_simd snd_hda_intel xt_hl nouveau snd_hda_codec hp_wmi wmi_bmof mxm_wmi sparse_keymap glue_helper snd_hda_core snd_hwdep cryptd ip6t_rt snd_pcm video ttm drm_kms_helper intel_cstate snd_seq_midi snd_seq_midi_event nf_conntrack_ipv6 nf_defrag_ipv6 snd_rawmidi intel_rapl_perf ipt_REJECT nf_reject_ipv4 snd_seq snd_seq_device snd_timer drm i2c_algo_bit fb_sys_fops syscopyarea sysfillrect sysimgblt nf_log_ipv4 serio_raw nf_log_common
[ 360.388005] lpc_ich xt_LOG snd shpchp xt_limit xt_tcpudp soundcore xt_addrtype nf_conntrack_ipv4 nf_defrag_ipv4 mac_hid xt_conntrack mei_me mei ip6table_filter wmi tpm_infineon sch_fq_codel ip6_tables nf_conntrack_netbios_ns nf_conntrack_broadcast nf_nat_ftp nf_nat nf_conntrack_ftp nf_conntrack libcrc32c parport_pc ppdev iptable_filter lp parport ip_tables x_tables autofs4 hid_generic usbhid hid psmouse e1000e ahci ptp pps_core libahci
[ 360.388070] CPU: 0 PID: 3893 Comm: insmod Tainted: G OE 4.15.0-76-generic #86-Ubuntu
[ 360.388079] Hardware name: Hewlett-Packard HP Z440 Workstation/212B, BIOS M60 v01.65 11/19/2015
[ 360.388096] RIP: 0010:xdma_kthread_start+0x9a/0x120 [xdma]
[ 360.388103] RSP: 0018:ffffa5690b0b7bf8 EFLAGS: 00010206
[ 360.388112] RAX: 000000000001ec20 RBX: ffff938fa097da20 RCX: ffffffffc0aa4e91
[ 360.388120] RDX: ffffffffbee80000 RSI: ffff938fa097da20 RDI: ffffffffc0aa20c0
[ 360.388128] RBP: ffffa5690b0b7c10 R08: ffff938fa097da24 R09: ffff938fa097da24
[ 360.388137] R10: 0000000000000277 R11: ffff938fa097da33 R12: ffff938fa097da24
[ 360.388145] R13: 0000000000000004 R14: ffffffffc0aa2070 R15: ffffffffc0aa2300
[ 360.388154] FS: 00007f6082299540(0000) GS:ffff93902fc00000(0000) knlGS:0000000000000000
[ 360.388163] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 360.388171] CR2: ffffffffbee9ec20 CR3: 0000000fe052e003 CR4: 00000000001606f0
[ 360.388179] Call Trace:
[ 360.388193] xdma_threads_create+0xee/0x160 [xdma]
The second VM does not have any FPGA hardware. For that 5.0.0 kernel, the driver source had to be modified as per: https://forums.xilinx.com/t5/PCIe-and-CPM/PCIe-DMA-driver-compilation-issues-in-Linux-Ubuntu-19-04/td-p/1022239 to get it to compile.
How can I fix this problem? And why 8?
Thanks in advance.
yosana
I have same problem on Ubuntu 18 (4.15.0-76-generic #86-Ubuntu), but crash happens in fist xdma_kthread_create() in my case.
dmesg output:
[ 63.536210] xdma: loading out-of-tree module taints kernel.
[ 63.536270] xdma: module verification failed: signature and/or required key missing - tainting kernel
[ 63.536795] xdma:xdma_mod_init: Xilinx XDMA Reference Driver xdma v2019.2.51
[ 63.536796] xdma:xdma_mod_init: desc_blen_max: 0xfffffff/268435455, sgdma_timeout: 10 sec.
[ 63.536806] xdma:xdma_threads_create: xdma_threads_create
[ 63.537365] BUG: unable to handle kernel paging request at ffffffffb9c9ec20
[ 63.537427] IP: xdma_kthread_start+0x9a/0x120 [xdma]
[ 63.537461] PGD 61a0e067 P4D 61a0e067 PUD 61a0f063 PMD 45bb59063 PTE 80003fff9e361062
[ 63.537520] Oops: 0000 [#1] SMP PTI
[ 63.537544] Modules linked in: xdma(OE+) nfsv3 nfs_acl nfs lockd grace fscache snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic joydev input_leds snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm intel_rapl x86_pkg_temp_thermal snd_seq_midi intel_powerclamp hid_generic mxm_wmi coretemp snd_seq_midi_event kvm_intel kvm snd_rawmidi irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcbc i915 snd_seq aesni_intel snd_seq_device aes_x86_64 snd_timer crypto_simd glue_helper cryptd intel_cstate drm_kms_helper intel_rapl_perf snd usbhid hid drm soundcore i2c_algo_bit fb_sys_fops syscopyarea mei_me sysfillrect mei shpchp intel_pch_thermal sysimgblt wmi video acpi_pad mac_hid sch_fq_codel parport_pc ppdev sunrpc lp parport ip_tables x_tables autofs4 e1000e ptp r8169 pps_core
[ 63.537881] ahci mii libahci
[ 63.537894] CPU: 0 PID: 1103 Comm: insmod Tainted: G OE 4.15.0-76-generic #86-Ubuntu
[ 63.537955] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./Z170M-ITX/ac, BIOS P7.00 10/26/2016
[ 63.537989] RIP: 0010:xdma_kthread_start+0x9a/0x120 [xdma]
[ 63.538007] RSP: 0018:ffffaa9781f27bf8 EFLAGS: 00010206
[ 63.538024] RAX: 000000000001ec20 RBX: ffff89299af5da20 RCX: ffffffffc080ae91
[ 63.538046] RDX: ffffffffb9c80000 RSI: ffff89299af5da20 RDI: ffffffffc08080c0
[ 63.538068] RBP: ffffaa9781f27c10 R08: ffff89299af5da24 R09: ffff89299af5da24
[ 63.538091] R10: 00000000000003cb R11: ffff89299af5da33 R12: ffff89299af5da24
[ 63.538113] R13: 0000000000000004 R14: ffffffffc0808070 R15: ffffffffc0808300
[ 63.538135] FS: 00007fc79691c540(0000) GS:ffff8929b5c00000(0000) knlGS:0000000000000000
[ 63.538160] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 63.538178] CR2: ffffffffb9c9ec20 CR3: 0000000460f70003 CR4: 00000000003606f0
[ 63.538209] Call Trace:
[ 63.538233] xdma_threads_create+0xd7/0x140 [xdma]
[ 63.538264] ? 0xffffffffc040e000
[ 63.538278] xdma_cdev_init+0x6c/0x90 [xdma]
[ 63.538295] xdma_mod_init+0x60/0x1000 [xdma]
[ 63.538312] do_one_initcall+0x52/0x19f
[ 63.538326] ? _cond_resched+0x19/0x40
[ 63.538340] ? kmem_cache_alloc_trace+0xa6/0x1b0
[ 63.538357] ? do_init_module+0x27/0x213
[ 63.538371] do_init_module+0x5f/0x213
[ 63.538399] load_module+0x16bc/0x1f10
[ 63.538415] ? ima_post_read_file+0x96/0xa0
[ 63.538432] SYSC_finit_module+0xfc/0x120
[ 63.538448] ? SYSC_finit_module+0xfc/0x120
[ 63.538465] SyS_finit_module+0xe/0x10
[ 63.538480] do_syscall_64+0x73/0x130
[ 63.538495] entry_SYSCALL_64_after_hwframe+0x3d/0xa2
[ 63.538513] RIP: 0033:0x7fc796435839
[ 63.538527] RSP: 002b:00007ffdaddca148 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 63.538553] RAX: ffffffffffffffda RBX: 000055827d24d780 RCX: 00007fc796435839
[ 63.538577] RDX: 0000000000000000 RSI: 000055827b36cd2e RDI: 0000000000000003
[ 63.538601] RBP: 000055827b36cd2e R08: 0000000000000000 R09: 00007fc796708000
[ 63.538625] R10: 0000000000000003 R11: 0000000000000246 R12: 0000000000000000
[ 63.538650] R13: 000055827d24fe90 R14: 0000000000000000 R15: 0000000000000000
[ 63.538674] Code: dd e3 ec f7 0f b7 53 14 48 c7 c0 20 ec 01 00 4d 89 e0 48 c7 c1 91 ae 80 c0 48 89 de 48 c7 c7 c0 80 80 c0 48 8b 14 d5 e0 b6 7a b9 <8b> 14 02 e8 1e 99 ea f7 48 3d 00 f0 ff ff 48 89 43 48 77 1e 0f
[ 63.538757] RIP: xdma_kthread_start+0x9a/0x120 [xdma] RSP: ffffaa9781f27bf8
[ 63.538781] CR2: ffffffffb9c9ec20
[ 63.538795] ---[ end trace 623182c6a77702c3 ]---
yosana
FIY, XDMA driver HEAD commit 8b8c70b697f049649d5fa99be9c6bc4302d89ac9 is working for me now.
syamcr
@yosanaThanks a ton for that info.
I too can confirm that 8b8c70b697f049649d5fa99be9c6bc4302d89ac9 is compiling fine and does not crash when the module is inserted. I have not tried actual data transfer yet though. @yosana Have you been able to successfully transfer data with this version?
yosana
Yes, I've tested with Gen3 x8 XDMA core generated by Vivado 2019.2 on my KCU1500 board (XCKU115 FPGA). But my test was just 4KB send/recv.
