PCIe DMA subsystem (AXI bridge mode) outstanding issue (ZU19EG)
We are implementing a PCIe DMA subsystem (AXI-Bridge mode) in ZU19EG device with Vivado 2019.2. We encounter a performance issue, similar to  the report : AR#72747 in xilinx website: https://www.xilinx.com/support/answers/72747.html .
The AXI outstanding number is set to be 8 (C_S_AXI_NUM_READ = 8), but we found only one AXI read can be issued instead of 8.  Please check "pcie_axis_arvalid" and "pcie_axis_arready" in the attached waveform.  This problem limited our design's performance due to very low data rate in the AXI read channel. Do anyone kown how to increase the outstanding number ?
Re: PCIe DMA subsystem (AXI bridge mode) outstanding issue (ZU19EG)
Could you check if "AXI Slave narow burst support" is enabled or not? If it is, please try by disabling this option. You will find this option in "AXI:MISC" tab in the core configuraiton GUI.
Thanks for your reply!
I am sure "AXI Slave narow burst support" is disabled.
The AXI outstanding works after disable ""AXI Slave narow burst". Thanks a lot!
