PCIe DMA system tutorial
After designing a successful PCIe DMA system using Xilinx XDMA core, I thought to share a fully extensive guide on how to do it right. I've posted it in Linked. You're welcome to read it:
Part 1: www.linkedin.com/pulse/xilinx-dma-pcie-tutorial-part-1-roy-messinger/
Part 2: www.linkedin.com/pulse/xilinx-dma-pcie-tutorial-part-2-roy-messinger/
Part 3: www.linkedin.com/pulse/xilinx-dma-pcie-tutorial-part-3-roy-messinger/
Enjoy!
Roy
Tags (4)
Indeed, I fixed all these issues. Thx. Good luck.
Many thanks for sharing this tutorial. It is indeed a great effort. I am sure many XDMA IP users will find this useful. If you have other tutorials you might have put together, please share those too.
Thanks again.
@roymesi2 Thanks for creating and sharing this tutorial!
Are you sharing the project files as well?
I'm reviewing the accuracy of this tutorial by following the steps but finding some inconsistencies. I'm only on creating Block 2 but seeing the comments mention to use axi master bus, but the screenshots show a slave bus.  Also in the overall block diagram, there are additional ports (i.e. "cpu_data_bus_rd[31:0]" which are not mentioned in this section.
I'm still going through it so if these issues are resolved later, then you can ignore my comments.
No. This is a guide. Not solution files.
Take into account you will need some degree of design level, as I could not give the whole design at such high resolution and explanations. There are alot of do's and don'ts and many guidelines.
Thanks for the comments, though. I will go over it and fix the issues where needed.
Also noticed block 6 isn't defined at all in part 3.
