PCIe XDMA scripting error
I am implementing XDMA by xilperl script command as per xapp1052 guidelines.(pg9).
--> ERROR:Xst:438 - Can not open file : xst.prj
is there any .xst file I should keep in xst folder?
what other things can cause this problem?
How to manulaly create this .scr,.xst file with respect to our project?
Thanks!
Avinash
Re: PCIe XDMA scripting error
Hi Avinash,
"In the .xst file, a .prj file is specified with -ifn option. Have you put this .prj file in the directory that is specified in the .xst file?"
Also "if you have a project setup on your local machine, you can use "Generate Tcl script" and then transfer the sources etc. together with the script to the server (if you don't have your project folder there already). Then you can start the script by e.g: "xtclsh make_my_project.tcl rebuild_project"
Hope this helps!
Ebrahim
Hi Avinash,
Hope this helps!
Ebrahim
Hi Ebrahim  @ebrahimm ,
Thanks for the help, my project files were not present in specified path and now problem is solved.
I got some other error as below,
ERROR:NgdBuild:1364 - Top-level input design file
"E:/Xilinx_ISE_DS_Win_14.7_1015_1/projects/bmd_design/ipcore_dir/bmd_design/d ma_performance_demo/fpga/implement/results/xilinx_pci_exp_ep_top.ngc" cannot be found or created. Please make sure the source file exists and is of a recognized netlist format (e.g., ngo, ngc, edif, edn, or edf).
Why it is not able to create that file, can you please help me out here?
Thanks!
Avinash
