10-17-2018 01:47 PM - edited 10-17-2018 03:11 PM
We're looking at using the Zynq Ultrascale+ family of parts with the PCIe integrated IP on the device. Our configuration would be PCIe gen 3 x 8 and was wondering if bifurcation of the bus has been done with this IP? Our intention is to have 4 lanes to a M2 connector and the other 4 to a PCIe slot. The IP would be configured as PCIe bridge - root port.
10-18-2018 08:57 AM
Hi @jayshu,
A single core instantiated in a part cannot be bifrucated down into two connections for the Root Port IP. This would require a switch in between. That being said, if you select a part in which you can instantiate 2 AXI Bridge Root Port IPs, you could create them each with a Gen3 x4 connectivity. This would appear as 2 separate root ports, but that would be a way to do it within a single part.
10-18-2018 08:57 AM
Hi @jayshu,
