PCIe core R/W latency
I have recently tested ML555 xilinx board with the generated PCIe example design.
I have tried to measure the latency on R or W operation using 2 different systems. (One I7 and one C2D )
Though the results differ a little I have achieved a 1000 ns on Read and 400 ns on Write.
With an Nvidia PCIe card the results are 600 ns on R and 100 ns on W.
The PCIe was Logicore Block Plus v 1.11 using ISE 12.1
Am I doing something wrong but on an old PCI design W latency was also arr. 100ns.
I had a look inside the example design and could not find anything that can lead to increased latency.
Is there a way to lower access  latency?
How are you measuring the latency? Is it the time through the GTP and the PCIe core or it involves the user application as well? I would suggest to check the latency in simulation. You could check for 'FB' (start of TLP) at GTP interface and then look for the corresponding trn_rsof at the trn interface. The difference in time between these two points will give you the latency through the core.
I am mapping to memory ( mmap() )all the suitable BARs and then measuring the memory transfer to that region with a simple program.
