Observer praful.r
PCIe example design simulation issue
I am using xilinx PCIe gen 3 subsystem. I have opened the example project and tried to simulate the one. Unfortunately only one read and write is happening through PCIe-AXI. How can I increase the number of read and write in the PCIe-AXI? Is there any parameter to change in example design? pls help
Re: PCIe example design simulation issue
Hi @praful.r,
Are you targeting the AXI Bridge functionality?  Are you Root Port or Endpoint?
For the Endpoint benches, you will want to modify the sample_tests.vh file to add more read and write.  We provide TSKs in the tx_usrapp source on the RP model to achieve this.
Observer praful.r
Thank you very much.. It worked as per your suggestion
