pumpkin
PCIe hardcore jammed?
Hi all,
I'm using V7 PCIe hardcore, and I have a bus master design to transmit data through RQ interface to host memory.
After running for several seconds ( several Gig bytes transfered ), the PCIe device disappeared in Windows Device Manager. Even after hot reboot the PC ( without re-configure FPGA ) , the device still couldn't be found. It looks like the hardcore is jammed.
What is the probable cause of this problem?
regards
Xiang Chao
kotir
Check if there is any error happend line fatal error where the behaviour of system can not be predicted.
Try to trigger on link loss signal (or cfg_err interface) and capture the packets sent/received. Check for any issue.
KR
