Visitor philipp
PCIe lane order with DMA/Bridge Subsystem for PCI Express
i am using the ip core "DMA/Bridge Subsystem for PCI Express" for my xc7a200tfbg484-2 device and want to change the lane order. Every time when i changed the lane order in "I/O Ports" tab to my physical order, it will be changed after synthesis and implementation automatically.
In my opinion the .xdc file ("...pcie2_ip-PCIE_X0Y0.xdc") of the ip sources fix lane with the MGT pin. Can i changed the mapping between MGT pins and pcie lanes?
I have also found the keywoard "DISABLE_LANE_REVERSAL". I set it to FALSE but, when i synthesis the ip core the value will be changed.
How can I changed the mapping between MGT and pcie lane order?
回复: PCIe lane order with DMA/Bridge Subsystem for PCI Express
Yes you can change  the code in("...pcie2_ip-PCIE_X0Y0.xdc") of the ip sources fix lane with the MGT pin.
you can run
set_property  is_locked true  [ get_files xxx.xci]
modify the code with other editor
and reload the xci file in vivado
you can run
Check if this thread helps.
https://forums.xilinx.com/t5/PCI-Express/Some-questions-about-PCIE-lanes-exchange-inside/m-p/877821#M11643
Visitor philipp
Thanks for your reply.
you can run
I have modified the .xdc file that you have mentioned and i have successfully changed the mapping between lanes and MGT pins. But I get bus error on the pcie on my own designed board. Can i excluded the ip core. On the Evalboard AC701 it is already running.
But I dont understand your following post. That is only for locking the ip core version? The functionality doesnt change?
