01-02-2020 05:17 AM
This issue is specific to FC30. I'm not facing this link down failure in FC25. Has someone come across this issue?
Following is the place where it failed
>power cycle the host(skylake)
>device and link is fine
>remove - device is removed
>rescan --> pcie link down
02-27-2020 05:57 AM
No we haven't seen this issue. Is this happening only when you connect to a Xilinx IP or you see the same issue with other PCIe IPs too? Also, it might be good to check if there are any BIOS updates.
