abob
PCIe multi-function device based on XDMA
Hi!
I explored SDAccel KCU1500 reference design and found that is is possible to create PCIE device with multiple  functions based on XDMA core. There is 2 PCIe functions on single XDMA core in SDAccel KCU1500 reference design. But it seems there is nothing about creating multi-function device in XMDA documentation
Is any documentation or application notes exists on this topic?  Any help, describing how to do this?
I need to do the same thing on my FPGA board.
Thanks in advance!
bethe
This function is specific to the SDAccel core and not general availability.   The second PF is not a second PF for the XDMA functionality, and instead has different usage specific to the SDAccel environment and driver.
hanban911
is there any way to disable pf1 on the kcu1500? i don't want  a multifunction device
