zhikai
PCIe sys_clk port selection about 7 series FPGA
When I opened the pcie3_7x_0_qpll_wrapper.v in the PCIe core, I found the QPLLREFCLKSEL port of the GTXE2_COMMON primitive is a constant 3'd1, which means that GTREFCLK0 is selected as the input reference clock to the QPLL according to ug476.
So I want to know whether I can use the MGTREFCLK1P/MGTREFCLK1n pins in the same GTX Quad ? Or do I have to use the MGTREFCLK0P/MGTREFCLK0n pins as the sys_clk in the PCIe core?
coryb
Hello @zhikai,
You can select MGTREFCLK0 or MGTREFCLK1 for your pinout of sysclk. Both are supported. GTXE2_COMMON will always use the GTREFLK0 port within the IP no matter what MGTREFCLK you decide to use in that quad.
Cory
coryb
Hello @zhikai,
Cory
zhikai
Thank you @coryb, I'll try it.
