cgrant
PCIe through FMC on ZCU111
Has anyone around here had any experience getting a PCIe endpoint to work through the FMC site to a host? What hardware did you use to connect the board to PCIe, and did you have to do anything special in the FPGA to get your PCIe device to enumerate?
Cam
pvenugo
@cgrant ,
I have not tried but for ZCU111 as PCIe finger is not available you need to look for FMC based PCIe daughter card to plug on to FMC header.
Praveen
