Visitor vigunawa
PCIe transfer fails when mutliple blocks access the same memory
I am currently developing on the KCU105 board and using Ubuntu 16.04 as the PC host. I have a pretty simple setup that I am trying to get working. I have some data being written into the on board DDR4 using an AXI MM interface. I want to move this data to the host using PCIe. I used the DMA/Bridge system in MM mode to implement this. I have setup the example design for the DMA/Bridge system and used the Xilinx provided drivers. This works quite nicely, run_tests.sh completes successfully.
After some testing and I found out that having multiple things access the memory causes run_tests.sh to fail. Particularly it returns W off or R off error. This message shows up when the number of bytes TO BE written does not equal the number of bytes actually written (can be seen in dma_utils.c). The number of bytes being written seems to return 0xFFFFFFFF...... as if it does not know when to stop. I do not have much experience with writing drivers so some details in the code flies right by me i.e. how write(2) command works.
I have attached a screenshot showing the difference. The left side is the setup I am having trouble with. I made sure that both XDMA cores are connected to S00 and preserved all the connections (i.e. ACLK,M00,S00) as much as possible. I might have overlooked something but I am not sure. Any feedback would be very helpful. Thanks!
Victor
Re: PCIe transfer fails when mutliple blocks access the same memory
What is the offset address for the M_AXI to DDR? Is it 0x0000_0000? The run_tests script assumes the offset to be at 0x0000_0000.
Visitor vigunawa
Ah yes that makes run_test.sh work. Thank you!
On another note, should perform_hwcount.sh also work without a problem because running perform_hwcount.sh seems to fail after the initial 64byte test? Then afterwards it would cause an error on the particular channel ie. after h2c_0 is tested through perform_hwcount.sh, dma_to_device command issued to h2c_0 reports an error.
-Victor
Can you please create a new thread with more details of your observations?
Please provide the dma_to_device command the result echoed by the driver.
