Anonymous
Not applicable
Pcie reference design on Spartan SP605 board
Hi all,
I'm trying to build the pcie reference design for the Spartan6 SP605 board.
If I choose VHDL in the coregen project the design doesn't work properly:  when I try it connected to a pcie slot in my PC the PC crashes when I try to read the memory with the pcitree program, and if I try the linux driver and example from xapp1022 it throws incorrect data when reading: always 0xFFFFFFFF.
But if I do the reference design choosing Verilog in coregen everything works OK.
I also have tried to do a mix project, some files in verilog and some in VHDL, to try to isolate the error. Finally I have found that the error is in the PIO_32_RX_ENGINE: I use a project with all generated files in VHDL except the PIO_32_RX_ENGINE that I use the verilog version, and it works OK.
Any clues about that? I don't know verilog enough to compare both versions and find the mistake.
Pablo
Hi Pablo,
I had the same problem with the SP605 ref board when using VHDL as the top language. I found that the "req_compl_with_data_o" signal was not properly initialysed in the provided VHDL design. You should change the following two lines in the "PIO_32_RX_ENGINE.vhd" file :
req_compl_with_data_o    <= '1' after TCQ;     -- line 162, was '0' in the original file
req_compl_with_data_o    <= '1' after TCQ;     -- line 184, was '0' in the original file
Simon
Hi Pablo,
Simon
Anonymous
Not applicable
Thank you very much!
It works OK now.
Can't understand how Xilinx tools may have this kind of silly bugs . . .
Pablo
thanks,
this post also helped me !!!! :)
Hi all,
Sorry for any problems this has caused.  This issue will be fixed when 12.1 is released.
Jason
I have another problem that apparently you did not have, it is the UCF file. It seems that the UCF file delivered online is not the good not. Would it be possible that you send me (of display in this forum) the UCF that you used for the Pcie reference design ?
