eric_fpga
Problem about "PCI_LC_I" file in 32bit target/initiator PCI Core
I've got an evaluation license for PCI Core,when I using the "ping" example,there is a file named "PCI_LC_I".On the top of this file there is a comment says "This file cannot be synthesized and should only be used
with supported simulation tools".So how can I get a proper file for synthesizing?
Can someone help me?
thanks
kotir
PCI_LC_I.v/vhd is the structual simulation netlist file. This is not for synthesis.
You can add this but will not be synthesized as the simulation part of the file is seperated by synopsys_translate off attribute.
It will not cause error even if you add this to synthesis files.
If you are using core gen then you might be using the v3.167.
For synthesis below are the files.
The netlist ngo file need to be pickedup from the src/xpci folder
KR
kotir
What exactly the device targetted and tool version ?
KR
kotir
Hi ,
When i load an example design of PCI core targetted for A7. I see as below.
Green box points to files for synthesis and blue box points to simulation.
KR
eric_fpga
I'm using ISE 14.7 and i'm targeting SPARTAN3AN XC3S200AN-5ftg256
what shoud I do with this tools and this target?
thanks
yenigal
You need to use the netlist file instead of the simulation file.
Check below AR
http://www.xilinx.com/support/answers/10235.html
Satish
kotir
KR
eric_fpga
Thank you very very much,it works.
