Problem with B_GTXE2_CHANNEL when trying to simulate PCIe Core in ModelSim
I'm trying to simulate the PCIe core in a Kintex-7 with Modelsim.
I've tried ISE13.4 & 14.1
I've generated the libraries with CompXLib...
When I start the simulation in modelsim, I get this error when it pass by PCIe_2X8_gt_wrapper
# Loading work.PCIe_2X8_gt_wrapper # Loading C:/Xilinx/14.1/ISE_DS/ISE/verilog/mti_de/10.1a/nt/unisims_ver.GTXE2_CHANNEL # ** Error: (vsim-3033) C:/Xilinx/14.1/ISE_DS/ISE/verilog/src/unisims/GTXE2_CHANNEL.v(3191): Instantiation of 'B_GTXE2_CHANNEL' failed. The design unit was not found. # #         Region: /board/EP/PCIe_2X8_i/gt_top_i/pipe_wrapper_i/pipe_lane[0]/gt_wrapper_i/gtx_channel/gtxe2_channel_i #         Searched libraries: #             C:\Xilinx\14.1\ISE_DS\ISE\verilog\mti_de\10.1a\nt\unisims_ver #             C:\Xilinx\14.1\ISE_DS\ISE\verilog\mti_de\10.1a\nt\unisims_ver
the simulator doesn't find 'B_GTXE2_CHANNEL'  in any libraries... neither I...
Can anyone help me with that?
I've the same problem just with differnet interfece. I'm trying to simulate JEDEC204B (v2.1) generated by Xilinx Core Generator version 14.1.
    B_GTXE2_CHANNEL_INST (
ncelab: *E,CUVMUR (/cadappl/ictools/xilinx_ise/14.1/ISE_DS/ISE/verilog/src/unisims/GTXE2_CHANNEL.v,2959|23): instance 'demo_tb.DUT@jesd204_v2_1_example_design<module>.i_jesd204_v2_1_block@jesd204_v2_1_block<module>.i_gtwizard_v2_1_top@jesd204_v2_1_gtwizard_v2_1_top<module>.gtwizard_v2_1_i@jesd204_v2_1_gtwizard_v2_1<module>.gt0_gtwizard_v2_1_i@jesd204_v2_1_gtwizard_v2_1_GT<module>.gtxe2_i@GTXE2_CHANNEL<module>.B_GTXE2_CHANNEL_INST' of design unit 'B_GTXE2_CHANNEL' is unresolved in 'worklib.GTXE2_CHANNEL:module'.
Did you or anyone else found some solution of that?
Within your vsim command do you make sure to include the following:
-L secureip
Let me know if you have already done that.
Hi luisb,
do you know if there is necessery some special license feature to compile the encrypted secureIP libraries for NC-VERILOG tool?
Because when I added then into the command line I obtained other error message:
ncverilog(64): 09.20-s038: (c) Copyright 1995-2011 Cadence Design Systems, Inc.
file: /proj/ibeta/users/ludekf/.caddata/xilinx/ISE_DS/ISE/secureip/ncsim/gtxe2_common_ncsim/gtxe2_common_001.vp
l=Q>[\@KNI999999T1r/v6bQbKRxxxijvtLch5VP3jPP58cezcFKU4wp2VrZ/AaoZffZg+EvFLCi
ncvlog: *F,DECERR (/proj/ibeta/users/ludekf/.caddata/xilinx/ISE_DS/ISE/secureip/ncsim/gtxe2_common_ncsim/gtxe2_common_001.vp,11|15): Error while decrypting : NO ERROR - Failed
unable to checkout license for encryption/decryption. 'lic_error -18'
My tool version is: ncverilog 09.20-s038
Thanks in advence!
Problem resolved...  newer version of the tool (ncverilog: 11.10-s022) doesn't need any special license feature.
