christophe0
Problem with PCI Express Example on Spartan6
I begin to  work with PCI Express and I want to run the example created by the Core Generator : the "PIO example design"
I have a Spartan6 (SP605).
I create a empty project under ISE (12.4) and add a "Spartan-6 Integrated Block for PCI Express v.1.4" with the Core Generator (I don't modify any parameter).
Then I open the project "PCIe_EP_vhdl_example_project.xise" that has been created. This project contains the PCIe_EndPoint IP,  the PIO application and the constraint file. I create the bitstream file.
First Remark, If I add a "Spartan-6 Integrated Block for PCI Express v.2.2" instead, I can't pass the "Translate" step. I don't understand why (ERROR:NgdBuild:604 - logical block 'PCIe_EP_i/axi_basic_top_inst' with type   'axi_basic_top' could not be resolved).
For the 1.4 version, no problem to create the bitstream. I flash it with Impact, connect the SP605 on the motherboard of another PC. Then I start the PC (with Windows) and use PCITree, but I never see my endpoint to appear.
Where am I wrong?
Thank you for your help
christophe0
I forgot : the SP605 obtains its power from the DC power supply (J18)
luisb
If you want to get the PIO example design working on the SP605, I recommend running through xtp065.  You can find it here:
http://www.xilinx.com/products/boards/sp605/reference_designs.htm
Hope this helps.
christophe0
Thank you for your answer. I will try this (I did not know this documentation).
