sasn1
Problem with XDMA Linux driver
I am experimenting with XDMA Tandem PCIe Core + Linux Driver. When used Tandem Configuration I cannot link up with MCAP.
I have been following both Xilinx AR#64761 and IP example. After programming the memory flash, I run the linux driver and I write the MCAP Device Id (same number which is in Xilinx IP)  but the linux drivers indicates "Xilinx MCAP device not found .. Exiting ...".
what am I doing wrong or missing here?
Thanks a lot!
deepeshm
First thing will be to check if the IP is detected using lspci. Let us know if you see the Xilinx IP listed.
