Problems of PCIE DMA simulation
hi, all,
         Recently i met a problem of pcie dma read data from system memory.
         I've created a PCIe EP core for the virtex 5 lx110t. I tried to run the example simulation. I code the DMA controller myself. And the Root Complex can read/write bar0 in the EP.
         But the RX of the Root complex could not receive read request from EP when the DMA_TX module of the DMA controller send a read request to Root complex.
I've attached here with the log message of my simulation.
          i can't unsterdand why the root complex recognize the read request as unsupported request. And what is the problem that cause this situation?
This error message is reported if the 'Memory Address Decoder Enable' bit of the command register of the Root Port Configuration Space is not set. This can be checked by looking at the cfg_command[1] signal in simulation.
The required tasks are already in the test bench of root port. You just need to call them  in your test bench. The tasks are the file pci_exp_usrapp_tx.v.
    // Direct Root Port to allow upstream traffic by enabling Mem, I/O and
    // BusMstr in the command register
    board.RP.cfg_usrapp.TSK_READ_CFG_DW(32'h00000001);
    board.RP.cfg_usrapp.TSK_WRITE_CFG_DW(32'h00000001, 32'h00000007, 4'b1110);
i hope the above suggetion helps.
sorry for my poor English and the rough pictures.
thanks for your suggestion. I resolved the problem by setting the "bus master bit" 1 which is default zero.
which parameter is bus master bit?
Bit 2 of command register
i want to simulate CPLD TLP, i configured the command register bit 2 to 1'b1, then sent the TSK_TX_COMPLETION_DATA, but the EP could not receive the CPLD TLP, what's the problem?
I meet the same problem with you,how do you solve the problem that sent the TSK_TX_COMPLETION_DATA, but the EP could not receive the CPLD TLP.
please tell us how to solute the problem,,,,,thanks
RP sent the TSK_TX_COMPLETION_DATA, but the EP could not receive the CPLD TLP. Where wroung?
HI Zhang,
Check for Max payload size parameter configured for RP as well as EP.
